Hi all
My TV capture card lets me superimpose a logo image upon the captured screen. But that logo image is in "yuv" format, anybody knows with which software I can edit/create the yuv files.
Thanks!!!
YUV is a color space format used by TV and DVD video. You can't save your still logo image in YUV format, at least from what I am aware of. You just save your logo as a regular JPG, BMP file or whatever your manual tells to. Your card should do the RGB-YUV conversion for you as it captures.
BTW, logos are universally HATED in this community. We try everything to get rid of them
By open the file in Notepad look for head info on the first line
Like
JFIF = JPG
GIF89 = GIF
BM60 = BMP
etc
etc -
Thanks for all your advices!!
I've just found a little program that can directly convert a 24-bit BMP file into a YUV file
My problem is now solved, thank you!!
How to Remove Logo From MKV File
By 09norcim in forum EditingReplies: 5Last Post: 9th Mar 2018, 06:59 -
How to create logo using aegisub
By Mildragon in forum EditingReplies: 2Last Post: 25th Oct 2011, 04:28 -
Adding a text logo to a video file without re-saving it to another file?
By coxanhvn in forum EditingReplies: 4Last Post: 19th Dec 2008, 16:03 -
how can create sub/idx with my logo ?
By persiansubtitle in forum SubtitleReplies: 0Last Post: 14th May 2008, 12:25 -
Help us create a new VideoHelp.com design and logo
By Baldrick in forum FeedbackReplies: 106Last Post: 1st Oct 2007, 00:36
