Hi
I have Star Wars Ep 2 but everyone sounds like Darth Vader. Think something is wrond with the Codec but i have no idea how to resolve it. Using Win Media 8
Help anybody. Thank you
Hippo
hungry hippo,
It's been a while since I had that particular file in my possesion, but if I remember correctly the audio was encoded in ac3. If your using the ac3 audio direct show filter included in the Nimo codec pack thats part of the problem. I recomend going to http://www.moonlight.co.il/download and downloading the Odio Dekoda and use this in it's place. I've had excellent results using this and highly recommend this to anyone trying to playback ac3 encoded files thru WMP.Warning! I'm baaaaaaaaack -
Hi kayfam
thanks for your help. i downloaded the odio dekoda. just want prob. the readme didnt say wat to do with it. ideas?
thanks -
hungry hippo,
Sorry about that. Assuming you extracted the files to the folder of your choice double click on the reg.bat file and reboot to make it go into effect. To remove it just double click on the unreg.bat file. It's that simple. Any other problems just PM me.Warning! I'm baaaaaaaaack
help with star wars saga br
By kn5150 in forum Blu-ray RippingReplies: 9Last Post: 21st Sep 2011, 16:55 -
Star Wars 3D
By stiltman in forum Off topicReplies: 20Last Post: 26th Oct 2010, 19:11 -
Why Darth Vader's Tie Fighter Never Appeared in Subsequent Star Wars Movies
By M Bruner in forum Off topicReplies: 11Last Post: 23rd May 2009, 20:58 -
Star Wars on a tight sound budget :)
By MackemX in forum Off topicReplies: 1Last Post: 3rd Jul 2007, 10:32 -
Star Wars: The Legacy Revealed
By JimmyJoeBob in forum Off topicReplies: 3Last Post: 1st Jun 2007, 18:14
