Hi there,
I have a problem with a capture (Batman 2K cartoon) I made in 352*576. I used the Morgan MJPEG codec in interlaced mode.
When I converted it to MPEG2 (Videodeluxe 2 with Ligos GoMotion), I saw the preview going back and forth on certain parts. Played on TV, it's a really ugly effect.
These parts show some interlace artifacts (horizontal lines) in the original capture. It appears on fast moving parts, but also some globally slow parts as well (where only the lips are moving for example).
I fixed the problem by deinterlacing before encoding, but I'd like to understand why this problem occurs.
Check this site, it has a good explination of interlacing
http://www.lukesvideo.com/
Craig
Media Recorder that can capture non interlaced (progressive, 720p) videos
By Daniel_BMS in forum Capturing and VCRReplies: 6Last Post: 24th Jul 2010, 10:19 -
Why are there spurious? frames in my interlaced PAL capture - sample clip
By BigMick in forum Capturing and VCRReplies: 5Last Post: 11th Jan 2010, 07:29 -
DVD to H.264 - Different Running Times, Chapter Times Wrong
By nrogers64 in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2009, 18:28 -
Capture settings or other issue? (Interlaced video, and a few questions...)
By DonnieC in forum Capturing and VCRReplies: 5Last Post: 30th Sep 2008, 12:03 -
Newbie frame/ field - capture both interlaced fields
By peter bradbeer in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 8th Feb 2008, 14:36
