Looking for advice on a new TV. Am looking at 47+" 16:9 HDTV ready projection and 42" plasma TVs. If I'm watching VCDs converted from Divx will the picture quality be so blocky that it's unwatchable? Right now I watch my VCDs on my 10 year old 27" TV. Any advice would be appreciated.
It just wont be HDTV quality since vcd doesnt take advantage of the HD standard. The resolution is to small.
A bird in the hand is worth a foot in the tush-Kelly Bundy -
Just make sure that whatever TV your buy has the picture noise reduction.
ya think if someone is gonna shell out a buttload of money for a cherry tv they'd consider buying a dvd burner and just forget about vcd..
vcd is not without its few certain charms, but dvd-r's are so much better..
[Help] Problems creating VCDs.
By scott274 in forum Newbie / General discussionsReplies: 77Last Post: 15th Jul 2008, 03:43 -
Multiple VCDs in one DVD
By vid_n000b in forum Authoring (DVD)Replies: 27Last Post: 30th Apr 2008, 03:52 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 11:38 -
I can not play some VCDs on my mechine. Can U help me ?
By wapw in forum Software PlayingReplies: 2Last Post: 21st Aug 2007, 12:46 -
extracting jpegs from vcds
By pk475 in forum Authoring (VCD/SVCD)Replies: 2Last Post: 9th Aug 2007, 11:38
