Has anyone tried Redhat 8 for Capturing / Editing ? Do you think its still worth running windows for programs like TMPGEnc ?
I use it as a server, and finally going to use it as a workstation !
Dan.
Im using 8, haven't used much in the way of compression tools though, but did find that i could install Cinerella, dvgrab and kino and they all worked straight up first go
was very happy with that!
spathi.net: My Corner of the Universe -
I use RH8 and have gotten TMPGEng12a and DVD2AVI 1.74 to run (in RH8) using wine... (though I doubt new versions of TMPGEnc would work under wine)
there are some decent (RPM & SRPM) repositories for audio/video stuff here:
http://ccrma-www.stanford.edu/planetccrma/software/
http://freshrpms.net/
http://gstreamer.net/releases/redhat/redhat-80-i386/
http://messlab.sourceforge.net/files/apt/redhat/8.0/en/i386/
that is if your lazy like me & don't want to compile everything yourself....
