Im looking for a simple program that will allow me to add a logo on my mpegs and save as the same mpeg without taking alot of time to encode the logo on it.
Virtual dub saves as AVI not mpeg.
I need an mpeg to mpeg program.
thanks
Steve -
Use VCDGear to make the mpeg - avi translation then use Virtua dub to add your logo or whatever then run it trough VCDGear to remake it as mpeg... This is probably the fastest & e-zyest way for a newbie...
Peace!
-RavedoG -
that is exactly the same as using virtualdub and than using tmpgenc cept now i got another program involved vcdgear.
thanks
Steve -
Just use an intro MPEG that has your logo - the logo won't be on every frame but you'll label the joined MPEG easily
Panasonic DMR-ES45VS, keep those discs a burnin' -
Oki! thats right it would be the same... do like this then... use myFlix (can be found in vcdhelp.com tool section) it will probably fix the problem
Have Phun!
-RavedoG
DVD authoring program that will add Macrovision
By Nolonemo in forum Authoring (VCD/SVCD)Replies: 19Last Post: 31st Oct 2010, 03:26 -
Need a program to add subtitles to an mkv file
By adamf154 in forum SubtitleReplies: 1Last Post: 12th Oct 2010, 00:59 -
Program to add a menu to a DVD...
By Soccerman77 in forum Authoring (DVD)Replies: 1Last Post: 14th Sep 2008, 03:45 -
Best program to add clips together?
By Soccerman77 in forum Video ConversionReplies: 3Last Post: 13th Oct 2007, 02:47 -
Need a program that can edit movies and add music
By LITEONDVD in forum Newbie / General discussionsReplies: 2Last Post: 28th Sep 2007, 16:20
