I downloaded this movie and originally I could only play the video but it couldn't play the audio. I installed the NiMo codecs (divx codecs 3,4 and 5 already installed before) and audio became available but for some reason playing the movie would periodically bring my CPU usage to 100%, making watching some sequences a chore. I am trying to convert the audio to a more standard format (mp3 layer 3 audio), but virtualdub won't allow any conversion. It returns an error:
The requested audio compression is not compatible with the input format. Check that the sampling rate and the channel count of the input match those of the requested format.
The weird thing is that I did just that (I set channel to stereo and sampling to 48000 Hz) but still it won't allow conversion.
Checking the file information from virtual dub, it says 48000Hz, stereo, but indicates the audio is unknown.
Is there any way I can convert this unknown audio format or is there a proper codec around to play it such that it can be played smoothly?
Thanks.
[/i]
it is most likely a ac3 file ...
use besweet and convert the ac3 file to somthing else ... -
come to think of it, the movie does have [ac3] on its filename. thanks.
is there a beginner's (or more blatantly, a dummy's) guide to using besweet or its gui? i was trying to rough it with the gui but I can't find the button which will actually run the procedure.
Unknown audio in AVI files
By courtneye in forum AudioReplies: 6Last Post: 29th Sep 2011, 10:24 -
Ripping CD (Enhanced Video) Unknown Format
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 30th Jan 2011, 20:20 -
Adventures in importing... unknown format in .mov wrapper
By vidhelp22 in forum Video ConversionReplies: 2Last Post: 19th Oct 2010, 23:30 -
Capturing unknown format video 8
By Bigby in forum Capturing and VCRReplies: 17Last Post: 28th Sep 2009, 09:10 -
How to Capture Video of "Unknown" Format from a DVD
By Hombre7 in forum Newbie / General discussionsReplies: 7Last Post: 11th Jan 2009, 12:14
