I use cladDVDXP to copy the vob files to my hard drive and then do the frame serving with DVD2AVI, at this point I can either use TMPGEnc to encode the file for burning to VCD or view the vob files directly from my computer, no matter which way I choose, the movie is stretched vertically, this is very obvious when look at people's face.
I am sure this is a setting's problem, but I tried to play with DVDXP and could not figure out what I did not do correctly, would appreciate any help.
Regards,
ML
when playing the vobs directly, the aspect ratio is usually off....this is normal..
however, for encoding in tmpgenc, use the following settings:
video output should be 4:3 Display NTSC
source video....aspect ratio (either 16:9 or 4:3 525 line NTSC), when creating the .d2v project file in dvd2avi, an info box should pop up telling you the source aspect ratio, this is what you enter in tmpgenc as source aspect ratio.
source video...image positioning method should be either fit to frame (preserve aspect ratio) or full screen (preserve aspect ratio) depending on which version of tmpgenc u have -
Thanks for info, I'll look for those settings when I do this next time!! Have a wonderful day!
ML
DVD Distortion on TV
By Craig Taylor in forum Authoring (DVD)Replies: 1Last Post: 2nd Apr 2011, 04:25 -
Audio distortion
By silveringking in forum AudioReplies: 0Last Post: 26th Jan 2011, 16:13 -
Distortion when played on TV
By tomhopkins in forum Authoring (DVD)Replies: 4Last Post: 18th Jul 2009, 15:36 -
DVD Flick created image distortion
By Vianty in forum Authoring (DVD)Replies: 7Last Post: 28th May 2009, 02:17 -
Audio distortion (clipping) on computer drives/players but not dvd players
By Left/Right in forum AudioReplies: 2Last Post: 5th Nov 2008, 19:21
