I edit a home mini dv movie in premiere and export the timeline as move. i burn the movie using nero as an svcd. i then play it and find sound and video is out of sync. I understand that this appears to be a common problem but have yet to receive any assistance that might help me rectify the problem. Also the video contect will stop, skip and jump at times.
any advice welcome.
Results 1 to 10 of 10
sounds like you let nero re-encode the movie .. do not under any case let nero encode anything ...
which version of premier are you using ? as it depends on what you do -
Thanks for the reply - i'm using premiere 6
nero is encoding the video - how do i stop it from doing that and still burn the svcd to disk?
mark -
export your movie from adobe as a avi interleaved file (you can use huffyuv to compress the avi in a lossless compression to save space).
set audio to 44.1 / 16 bit joint stereo or stereo.
download and install TMPGEnc mpeg encoder and select svcd template ..
load your avi you made into TMPEnc and hit go ...
load the resultant mpeg file in to nero svcd template ... if nero says its a non complacent mpeg file for svcd -- hit "turn off complacent"
burn -
OR
get a adobe mpeg2 plug in for encoding ///
but you will have to resize and such from within premier.. -
I followed the advice and downloaded TMPGEnc-2.58.44.152-Free and did as suggested and tried to load my avi file created with premiere 6 and could only load it in the audio stream line not the video - it then encoded it and when i played it back i only got audio of course. i tried again to load it in the video file section of the window and it told me that it was an unsupport file and gave me no options. What next?
Mark -
u do not have a mpeg2 decoder installed -- the easy method to do so is to install powerdvd which is supported by tmpgenc ..
that is the only problem .. -
I do have powerdvd - but it only played the audio - i was unable to load the avi into the TMPEnc video line only the audeo for some reason. it called the avi unsupported
Try this:
Capture and Edit in Premiere…
Encode and Burn in DVD Movie Factory…
This should give you great results, and will add more features in menu creation, etc…
It’s also very easy to use, plus it’s CHEAP! (and free to try)
You can download a trial copy of DVD Movie Factory from
http://www.ulead.com/dmf/runme.htm
It’s about $45.00
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Nero 7 audio sync problems
By CRJ705driver in forum Authoring (DVD)Replies: 5Last Post: 26th Sep 2010, 02:25 -
audio video avi file out of sync when converting with nero
By paulthewall37 in forum AudioReplies: 2Last Post: 28th Feb 2010, 18:06 -
I moderately dislike Nero Vision (audio sync)
By Matth3w in forum Newbie / General discussionsReplies: 4Last Post: 23rd Nov 2007, 19:53
