I am getting the error "can not open or unsupported" when I try to open a avi in TMPGEnc, but the thing is I have opened the same files with it lastnight. Any reason for this?
Something was messed up in the registry, I guess. You might need to reset your AVI file settings all over in the registry. Try this one and see if it fix it:
http://doom9.org/Soft21/SupportUtils/AviResetAll.zip -
hmm no good, it's still doing the same thing.
I also have another problem. The other day I downloaded Ringu and it does not play in Windows Media and gives me "format not supported", but it plays perfectly in Real.
WebEx WMV file, can't open in VirtualDub, says "missing codec"
By violetta in forum Newbie / General discussionsReplies: 13Last Post: 22nd Jul 2016, 21:39 -
For those who face the "windows media player cannot open this file" problem
By sanosuke in forum Software PlayingReplies: 0Last Post: 1st May 2011, 08:00 -
BR structured image file is found as "unsupported"
By besthost in forum Authoring (Blu-ray)Replies: 4Last Post: 28th Jun 2009, 02:06 -
"Unsupported audio rate in file" Message in Premiere Pro CS3
By JustinBaker in forum AudioReplies: 2Last Post: 23rd Mar 2008, 23:27 -
How to actually close "open GOPs" abd avoid warning with DVD Lab
By perfection in forum Authoring (DVD)Replies: 1Last Post: 31st Aug 2007, 23:42
