Results 1 to 10 of 10
  1. Member WishMaker's Avatar
    Florida, USA
    I went to a person's site and printed out a how to etc., but one of the tools that I'm supposed to have is TSCV.
    I click on his link to download TSCV and there's a page error.
    Does anyone know of a working link that will take me to a place I can download TSCV?
    PS: Would you make sure before you post the link that it is working? I'm getting dizzy going around in circles. Thanks in advance!!!
    Never discourage anyone...who continually makes progress, no matter how slow.
    Plato
    Jul 2002
    Erie, PA United States
    WishMaker,
    Try this link:
    http://www.tscv.org/download.htm
    Warning! I'm baaaaaaaaack
  3. Member WishMaker's Avatar
    Florida, USA
    kayfam,
    Thanks, but the links don't work. I click and it doesn't bring up anything to download...just File Not Found.
    Maybe your computer was able to get it because it was sprinkled with fairie dust and mine just with plain old dust.
    If you get a link to work, please post again.
    Plato
    Mar 2002
    canada
    i just tried "kayfam's" link. works ok 8)
    Jul 2002
    WishMaker,
    Try flushing your browser cache and give it another spin. I just tried the link and it's working fine.
  6. Hey guys - Wishmaker is saying that FILE DOWNLOAD link is not working in that site not the LINK to the the SITE itself. Just tried it - DOWNLOAD link to get file is NOT working.
  7. Member WishMaker's Avatar
    Florida, USA
    O Kewl,
    Whew! You hit it on the head.
    AND... Sorry to all those I confused by not wording my problem correctly.
    So... if anyone finds a working FILE DOWNLOAD link, post 'cause I'm definetely listening.
    PS: I also went back to the site where I printed out the "How To's" and emailed him as to how to get TSCV. I believe I got to his site from vcdhelp.com.
    The two "How-To's" are "VCD Stills with Audio" and "How to Make High Resolution VCD Stills". I wanted these to make custom MENUS.
    Plato
    Jul 2002
    WishMaker,
    I found an active link over at Doom9.org. I'm not sure it's the file you're looking for but it won't hurt to take a look. http://www.doom9.org/index.html?/mpg/tscv.htm Please note it's not an obvious link, just the name of the software is mentioned.
    Make sure your not using a download manager or you will get an anti-leech notice. Left click on TSCV and let windows handle the download. Also the file is in Rar format so you'll need something like WinRar to open it. Hope this helps
  9. You can also download TSCV at my site...
    Antonio S.
    http://www.antonio.owns.it
  10. Member WishMaker's Avatar
    Florida, USA
    kayfam & Antonio,
    Thank you, both! Downloaded both.
    Antonio, I chose the one slated as being "stable"
    Since I don't know which version will work best with the "How To's" I have, if one doesn't work maybe the other will.
    From what I can see on the picture of the "How To" print outs, the author is using TSCV v0 82 beta Rel 1
    You know how it goes when the "new and improved" comes out. They sometimes improve, but then take out things you need too.
    Of course, it's all in the scheme of planned obsolescense
    PS: Nice site, Antonio. I bookmarked it, of course
    Plato
