I caapture the video using this card and the resulting AVI video clip. I cannot convert the clip to vcd, it says illegal bitstream format. Can i convert the video to mpeg directly using this card, or can anyone help with the convertion of the avi file it is giving me.
thanks
mat
Hi, I use the Happaupage WinTV2000 that comes with my card. Since I have the divx codec's installed I can capture the AVI to a mpeg 4 format. If I use the standard uncompressed AVI I loose more frames than I capture.
I have done a few recordings at
25 Frames, audio Default PCM 8 "Divx Mpeg-4 fast motion" 352 X 288 24 bit color
This is then converted to PAL VCD using TMPGEnc
I experimented with all the codec's to see what quality I could get with the smallest size, and no frame loss. The AVI's are very good, and when placed on a VCD they look fine. In my case I use PAL VCD so you may want to capture at the NTSC size instead (352 X 240)
For some reason I cannot capture audio at anything else except the default PCM 8 (Line in)
Divx Mpeg-4 fast motion.avi
AVI to VCD with TMPGEnc
Hit File > Video Compression
keyframe every 10
<font size=-1>[ This Message was edited by: letmeinforgodsake on 2001-08-20 07:33:24 ]</font>
Problems Capturing from Vidoenics MX-1
By John Duvall in forum Capturing and VCRReplies: 0Last Post: 15th Dec 2010, 07:04 -
VHS Capturing problems
By scratchmeback in forum Capturing and VCRReplies: 15Last Post: 10th Jan 2010, 21:04 -
Capturing problems
By dbrunton in forum Capturing and VCRReplies: 9Last Post: 27th May 2009, 13:09 -
Having problems capturing my 360 on my PC
By RR420 in forum Capturing and VCRReplies: 4Last Post: 23rd Feb 2008, 10:50 -
Having problems capturing from VCR
By Confused Chimp in forum Newbie / General discussionsReplies: 5Last Post: 29th May 2007, 02:41
