Hi,
Why should I try to make my DVD2VCD with AC3 sound? What is AC3?
And if its "all that" ... how do I do it the easiest way (is there a guide for it in vcdhelp.com?)?
Thanks![]()
proctorGuest
u cant, except with a lot of problems (i can get it to work only 25% of the time or less) make a svcd with ac3
i'm sure ....
ac3 btw is the name for a dolby digital compressed audio file ... around here know often as DD .. it can be anywhere from mono to 6 channels (in fact really 8 sortof) ..
it is not supported on svcd's and vcd's -
i managed to do by making a transport stream mpeg muxed with mpeg2 and ac3 file ... then using transport stream convertor from either an old version of pixel tools or vitec to convert to a program stream ..
i think i also sometimes used a program to fix stream header.. bitrate viewer can do this in the full version ...
but it only worked not often and only in very few players.. so i gave up working on it as i saw no real reason for the effort anyway ...
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 12:23 -
MPEG4-AVC (H264) + AC3 -> Divx + AC3?
By thomas_fogh in forum Video ConversionReplies: 12Last Post: 1st Nov 2008, 21:25 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 08:06
