Hi
Which way is better??
Capture to DVD Mpeg2 then convert to VCD
or capture to DV then convert to VcD
thanks
More details! More details! What are you using to capture? What hardware? What software?
And most important, have you tried searching the forums for any existing messages that might give you help? Try searching on the name of your capture card or program, and check the guides written by people.Animation and geeky reviews and podcasts at
Cartoon Geeks (http://www.cartoongeeks.com) -
BV2001,
Actually capturing using uncompressed RGB or using Huffyuv (slightly compressed at roughly 2.5:1 and lossless) would guarentee the best results, but you need a massive amount of free hard disc space and is best done on an NT based OS such as Windows 2000 or Windows XP (virtually no file size restrictions) capturing to an NTFS formated partition.
I agree with tomreedtoon in that you need to post more details on what resources you have available.Warning! I'm baaaaaaaaack
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 12:42 -
Best video capture software? Is AVI better for capture? Is TV screen better
By johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 08:17 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 19:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 20:42
