Hi, Please let me know if u have sucess particuarly on the vcd issue...and can u play svcd...All comments are appreciated especially as its taken me yonks to find this hack
For anyone following my saga Ive had limited success
This applies definatelty a ferguson DVD400FE, which i have (live in the uk though i do know that thomson are pretty much the same company), is tevion DVD 200 the same machine...i really dont know but i try it as well.
Anyhoo for the ferguson for region free hack...which ive verified(2nd attemt) do the following
1 press menu on remote control
2 press the 1 button on your remote control
3 press the 6 button on your remote control
4 press the 7 button on your remote control
5 now press mute for all regions...make sure its the mute button your pressing
6 or you can press 1 for region 1, 2 for region 2 etc
7 it definately works so keep doing if u dont suceed the first time
VCD, now this is supposed to work ive tried it a 4 times...and so far with no success, though i will try it again tomorrow( if it works i will let u know if i can play vcd svcd etc but heres the instructions
1 press the OPEN on your remote control to open the drive tray
2 place an AUDIO cd in the drive tray
3 press the OPEN button on your remote control to close the drive tray
4 press the menu button on your remote control
5 press the 1 button on your remote control
6 press the INDEX (1-all) button on your remote control
7 press the OPEN button on your remote control
8 press the 1 button on your remote control
Now i can get a kinda all or all1 up on my tv screen but thats as far as i got...let me know if you have sucess and whether you can play vcd svcd etc
i will definately try it again and advise on the vcd issue..and hopefully SVCd issue
(remember comments are welcome by all)
nite
