I have 4 VCDS burnt onto CDS. but when i put them in my comp, nothing happens and there arent any files to "start it up". when i put it into my dvd player, it says it doesnt recognize the CD. whats going on?
they were able to be viewed through my cousin's vcd player, in taiwan. But they wont work here. please help
Pardon my ignorance but is Taiwan on a Pal or NTSC standard.
Is the country you are in on the same standard ?
They won't normally autoplay on your computer but should play if you have DVD software installed and you select the mpeg or dat file.
Microsoft Media player and most other players will play the same way but you must read the file directly or set up the association of the .dat or mpg to your player and then doubleclick on the file in the window explorer.
Your files are no doubt mpeg1 but just in case Mpeg2 files will require an mpeg2 decoder to play in the windows media player.There's not much to do but then I can't do much anyway.
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 11:26 -
Still confused on upconverting
By glp103 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Jan 2008, 16:42 -
resizing, I'm confused!!!
By nalooti in forum Video ConversionReplies: 5Last Post: 19th Nov 2007, 08:14 -
Confused about subtitles.
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 30th May 2007, 02:38 -
Really confused about resolutions....
By sam9s in forum DVB / IPTVReplies: 6Last Post: 12th May 2007, 12:42
