I have posted atleast 4 Topics trying to succesfully create a VCD with good quality and have been unsuccesful
1. I have tried to Jim Mangafas AVI to VCD conversion guide. I used TMPGE instaed of Panasonic MPEG1 Encoder.
2. I tried same guide above withe SVCD
3. I was told on this forum to use the Fameserver with Virtual DUB so I would not have to create the temporary file.
4. I was then told on this forum to use virtual dub as stated in item 1 above but not to use DIVX compression and use Huffyuv
All the above methods above were unsuccessful
The AVI file I am trying to covert is 11.998 FPS. Is this not high enough to create a good quality VCD
Please help
Any suggestions on which method would be apprecited
11.98 fps? With a frame rate like that, and a stamp-size resolution, it was meant to be streamed over the Net and played on computer, not to be converted to 25/30 fps and blown up to be played on TV. Of course, you can do it and the result is very crappy.
FashionDon2,
With the frame rate you have, I'd have to say there's likely no way you're going to get a good quality VCD. I've made some reasonable quality VCDs from 14.99fps AVI files using TMPGEnc and VCDEasy, but the best ones I've made have been from 29.97fps AVI files.
Is your video jerky? If so then its likely that its because your frame rate is too low and 29.97 isn't an even multiple of your frame rate (11.99?) 11.99 is close to half the frame rate of NTSC Film, you might try using a template that will convert the NTSC film to VCD and maybe use a 3:2 pulldown filter...Since all my source material is 29.97fps I've never had the need to do this so I can't tell you how good it will look...
Anyone else can help this poor soul with his 11.99fps movie?
CogoSWSDS
Making a VCD to send to the Philippines
By StrikerZERO in forum Authoring (VCD/SVCD)Replies: 17Last Post: 7th Dec 2010, 10:11 -
Is there a better method?
By quxote in forum Authoring (DVD)Replies: 4Last Post: 24th Nov 2009, 16:32 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 13:03 -
Making VCD Copy
By audiophile in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th Sep 2007, 08:20 -
General Guidance and Hardware req. for making VCD with Digital Camera
By dpilot83 in forum Newbie / General discussionsReplies: 4Last Post: 11th Jun 2007, 06:53
