Hi,
When I capture like 1 hour tape using PowerVCR in MPG2 DVD 740x280 resolution.... the file is autmatically split after 615MB like example for one hour the total size I expect is 6150MB ( 1 file big ) but this case it split in to 10 file of 615 each??? anyone know how to make it capture as 1 big file?????
thanks
first of all im not sure about this..
but i think power vcr is doin that coz ur on a FAT32 partition meaning it wouldnt allow u to capture more than 4Gb.. probably if u put ur output file on an NTFS partition PowerVCR wouldnt divide it.. i think..
:^)I FEAR NO BEER!!! -
I have already recently posted the way to change the default size split in powervcr more than once. (just check my posts or search for powervcr)
It involves simple changes in the registry.
If you are on a fat32 do not go over 4gig.
You have no profile info but if you have xp and an NTFS partition then you can set the limit to whatever you want.There's not much to do but then I can't do much anyway.
Power adapters for external capture cards
By pinetop in forum Capturing and VCRReplies: 0Last Post: 5th Mar 2011, 01:34 -
capture from vcr
By bbxrider in forum Capturing and VCRReplies: 27Last Post: 16th Aug 2009, 17:18 -
VCR capture troubleshoot
By Abas-Avara in forum Capturing and VCRReplies: 11Last Post: 16th Aug 2009, 05:26 -
capture video from VCR
By nbdeb59 in forum Capturing and VCRReplies: 2Last Post: 3rd Jul 2009, 00:57 -
Capture from VCR or Camera?
By thomasj in forum Capturing and VCRReplies: 3Last Post: 26th Nov 2008, 15:13
