I ripped the Eagles DVD When Hell Freezes Over. It only has DTS audio. When I try to import it into SpruceUp I get this error message: "Progressive Frame Flag In Picture Codeing Extension Is Set to 0". Anyone have any idea what this means? Any help is appreciated.
Thanks Boxingjunkie![]()
Not sure on that exact error but as fas as i know Spruce-up does not accept DTS audio so this might be your problem.
For DTS i always use DVD maestro or Scenarist -
The error that you received is referring to your video file - it hasn't even started the audio file. This error occurs when you take a progressive stream (24fps) and apply a 2:3 pulldown and don't set the progressive frame flag ("1" means that the video is a progressive stream pulled down to 29.97fps, and "0" means the video is straight interlaced 29.97fps). The program can see that it is not an interlaced sequence, since there are only 24 frames where there should be 30.
Take the .M2V video and re-run PULLDOWN and be sure to set "-PROG_FRAMES P" as one of the options. This will allow the video to import. Once this is done, Spruceup will not import any audio, since it can't handle DTS. -
Thanks SLK001! I had this exact problem converting a SVCD to DVDR. searched these forums for the answer and there it was. perfect explanation and another video hurdle tackled. thanks again!
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
