1 When I am finished with my editing, how do I properly save the avi as an MPEG?
2. Obviously I want some form of compression. What codec is recommended for filming cars street racing? Adobe defaults to cinepac by Radius I see.
3. I've tried exporting to MPEG before. But Adobe always made the MPEG bigger (higher resolution i guess) than the original AVI and it looked crappy. How do I correct this.
Thank you for taking the time to read my post
Regards
R
When you export to MPEG there should be options for it. Check to make sure your bitrate is not set too high. If your making VCD, SVCDs, XSVCDs or DVDs? This will determine what resolution and bitrate you encode at.
What codec you use is determined by what format you want to use it. VCDs – DVD use MPEG2. If you are going to put it on the web for download then Divx or Windows Media Encoder may be the better option…
Hope this helps…
Mavrick -
I guess you are using Premiere 6.0 or lower. Premiere 6.5 has default MainConcept MPEG-2 plug-in, which is excellent. Of course, you can also use other MPEG-2 plug-ins, such as CCE, to export your timeline. However, to configure settings for plug-in isn't that simple. CCE has no built-in resize filter, so prior to CCE 2.66, you can't export SVCD compliant MPEG-2 stream. I am going to install Premiere 6.5 tommorrow and have some fun
Can't edit video file converted from DVD to AVI in Adobe Premier
By GalMed in forum EditingReplies: 12Last Post: 24th Feb 2012, 14:53 -
Adobe Premier 5 AVI's won't load into Nero Vision 10
By rlarden in forum Video ConversionReplies: 1Last Post: 2nd Jul 2011, 05:43 -
Premier Pro CS3 exporting problem
By SB4 in forum EditingReplies: 0Last Post: 13th Dec 2010, 10:50 -
Premier CS4 exporting issue
By Jonza in forum EditingReplies: 2Last Post: 3rd Feb 2010, 05:08 -
Exporting HD in Premier Pro
By videopetur in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 5th Jan 2009, 16:20
