When I drag&drop the mpg file to the second entry in the bottom window, it takes the full file, but with my Hardware DVD Player, it doesn't work.
When I drop the file to somewhere below the second entry in the bottom window, it only takes roughly 15% of the file. Burning succeeds, and the Hardware DVD Player plays the 15% of the file. But I want the whole file (160 MB) to be located on the CD!
Is it a problem with WinonCD, or is it the problem that I used TMPEGEnc with standard SVCD (PAL) settings?
Should I use Nero instead? Which Version do I need?
Thanks for your help!
Geheimrat
Results 1 to 1 of 1
"Dirty disk" problem after burning. PLS HELP!
By mlo2102 in forum Authoring (DVD)Replies: 9Last Post: 29th Jun 2011, 15:17 -
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 11:59 -
ratio / format / codec problems, pls help!
By phaedrus in forum Video ConversionReplies: 5Last Post: 8th Jun 2008, 06:57 -
Svcd Burning
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 16th Apr 2008, 08:25 -
Burning SVCD to a DVD (Not converting!)
By bebopdeluxe in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2007, 09:06
