I have been reading alot of posts mentioning the NIMO Codec Pack, so I decided to download it just in case I may need some of them at some point.
I had already installed the latest DIVX, and MPEG2 codecs awhile ago (before I ever started burning VCD's) I used to just watch DIVX and(S)VCD on my puter, anyway....
I installed the nimo pack 8-- did a complete install without one of the audio codecs they say have a conflict.
I tried to view a svcd on my pc it was UPSIDE DOWN???
So I remember on the install they mentioned something about upside down video, so I unistalled and reinstalled and chose not to install the bicubic resizer.
Same result upside down video.
So I uninstalled again, rebooted..
My mpeg2 videos now played RIGHT SIDE UP, but I had No DIVX CODEC whatsoever,
So I tried to install the the NIMO lite pack..
I still cant play my DIVX..
Please Help,
SAME PROBLEM HERE NOW.
I use MediaPlayer9 (beta)
I want mediaplayer to be the default player for ALL media files.
But after installing Nimo (and uninstall it) Media player will
not play alot of mpeg files now.
Re-installing Mediaplayer9 does not help.
Nimo you need to stop releasing a pack that just creates
alot of problems. -
Try hanging allastic to your ceiling and flip your self upside down when playing movies enjoy!!!!!!!
any more super hints i will be charging by the ??? -
Looks like nimo codec pack overwrites previously installed codecs, so when you uninstall nimo you dont have the old codecs because they where "erased" by nimo(thats why I didnt install it). Try installing nimo lite then install the old codecs (if you still have the old installers).
XP Installations. Big problems.
By SE14man in forum Newbie / General discussionsReplies: 23Last Post: 9th Mar 2010, 09:43 -
Help reset my expectations - how big the rip will be, time it takes to..
By AndyD in forum Blu-ray RippingReplies: 3Last Post: 26th Nov 2009, 13:10 -
Error-time a sign of a none existing codec?
By Blå_Mocka in forum Newbie / General discussionsReplies: 2Last Post: 8th Apr 2008, 16:43 -
big conversion problems
By insyder in forum Video ConversionReplies: 0Last Post: 7th Jan 2008, 10:02 -
BIG problems with subtitles!!!!
By patoja76 in forum Authoring (DVD)Replies: 1Last Post: 11th Aug 2007, 11:00
