I have done several XVCDs (a whole movie on 1 cd) with TMPGenc Mpeg1 VBR CQ 55, maximum bitrate 1500, minimum 700, audio 128, mux as non/standard VCD and burn with Nero 5.5.
All these XVCDs have worked well with my Hollywood+, but last week I bought Philips DVD 622 player which plays these CDs but freezes occasionally for a while. I suspect this has to do with going under a minimum bitrate (problems occur most likely with widescreen DVD-rips and almost never with tv/captures).
Apparently TMPGEnc does require checking "Enable padding when falling below minimum bitrate" to create XVCDs that will play without problems on my player. However, selecting this option can increase the mpg file size quite a bit, so I would like to know if there is a common minimum bitrate below witch most standalone players encounter problems.
Results 1 to 1 of 1
How to set MINIMUM bitrate in VBR 2 -pass on TMPGEnc Authoringworks 4
By eltimbomofo in forum Authoring (DVD)Replies: 3Last Post: 9th Mar 2012, 16:59 -
Minimum Bitrate MPEG2 encoding
By Rob D. in forum ffmpegX general discussionReplies: 4Last Post: 14th Jul 2010, 10:44 -
Error in Variable bitrate (VBR) audio detected
By Russo in forum AudioReplies: 9Last Post: 12th Feb 2010, 09:01 -
bitrate lower than set when VBR rendering in Vegas 8
By gtmb in forum Video ConversionReplies: 2Last Post: 29th Sep 2008, 08:02 -
VBR (2 pass, average bitrate) Encoding for DVD-9
By jcm0320 in forum Video ConversionReplies: 3Last Post: 15th Aug 2007, 10:44
