I can't seem to encode an .asf video format to mpeg, I always get this Ilegal message box when using TMPGEnc. Can somebody help?
asf (wmv) is a valid format to tmpgenc so either you do not have the vfp (vfapi plugin) installed or the Option/Environmental settings/vfapi plugin settings are not correct.
Otherwise you need to identify where in tempgenc you are trying to select the file.
The only thing I haven't tried with tmpgenc is the new (asf) wmv9 codec so I can't be sure if tmpgenc accepts that one.There's not much to do but then I can't do much anyway. -
I believe .asf is _not_ a valid format due to Microsoft having a (very well protected) license on the format? .asf support was removed from for example VirtualDub since version "1.3d", which is the version you could use for frameserving to TMPGEnc, this at least would be a definite way to make your encode work if it wasn't totally illegal .)
So, you will not find this VirtualDub version on the VD site at least, good luck hunting it. The VD site, however, should still include explanation on the matter. I cannot vouch for the licensing reasons also prohibiting the file format support from TMPGEnc these days, I do know TMPGEnc didn't support .asf in the past.
asf to vc-1
By sampalmer21 in forum Video ConversionReplies: 1Last Post: 16th Dec 2009, 15:27 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
vc-1 to asf
By sampalmer21 in forum Video ConversionReplies: 3Last Post: 10th Nov 2009, 20:47 -
Conversion from asf files to avi or mpeg
By Jescal in forum Video ConversionReplies: 1Last Post: 23rd Jan 2008, 17:37 -
Convert AVI to MPEG-4 (asf) for DVD player
By digitalife in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2007, 12:49
