Ok I am trying to burn a data DVD in NERO which contains a DVD I RIPed already however once I get everything ready to burn when I click on burn it brings up a pop up screen that allows me to check everything but down at the bottom of the box it was a progress bar taht eventually fills that says "Waiting for the device to become ready..." and I can't go any farther, my DVD burner is a Phillips DVD+RW-D28 and the blank dvd I am using is a Memorex DVD-RW (4.7GB/120 min video) if anyone can help please do. thanks.
Make sure that you can use DVD-RW on you burner. Maybe you need DVD+RW...
Just a suggestion... -
The phillips drive most assuredly can not use - media it must be + media.Originally Posted by GenkaNT
Had the same problem with my dvd burner mine supports only DVD-R/RW
Not DVD + R/RW there is a difference. -
Definatly the media I have the same drive you want to use DVD+R and DVD+RW NOT -R or -RW
Noobish Nero DVD Burning problem (no space available for recording process)
By windowlicker in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2014, 12:24 -
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 12:59 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Sound Problem Burning DVD with Nero 7 and TMPGEnc
By brandonc in forum Authoring (DVD)Replies: 4Last Post: 28th Nov 2007, 20:40 -
nero burning problem
By peterjitonks in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2007, 14:40
