Here we go guys I have a quest....
I have'nt done a SVCD from a DivX file and plz I need some help with TMPGEnc Plus 2.5.:
My wav. file is on 574 mb and the video file is on 364 mb and I want to make a SVCD with the highest quality. So I open TMPGEnc and then I select witch format I want so I select PAL, and then NEXT. Then I came to the "Select source file" area so I browsed my movie into TMPGEnc ( one video file and one wav. file). Then NEXT. Then I came to the "Filter Setting" area and from there I clicked on "Other Settings". here is the first problem. On the Video part in Other Settings there is "Motion search precision" . There can I select the quality I think (or is it the quality that I select here?). So as I said first I want the best quality so should I select "Highest quality(very slow)" then???? or should I let it be on "normal"????
Plz help![]()
How long will the encoding take with this computer???
1.66MHz
256 RAM
80GB HD
OS: XP prof.
Need to know somthing more so just ask but remeber I WANT THE HIGHEST QUALITY.
I hope some nice guy have time to answer my question![]()
grrrrrrrrrrvooffff
Please only post a question in one forum only.
Panasonic DMR-ES45VS, keep those discs a burnin' -
If you want the highest quality, select highest quality. It will take longer - how long: who knows as we don't have your exact configuration. Set it up to run overnight or try encoding on a 30 sec clip to test.
Two simple questions, plz help!
By UnD3R0aTh in forum DVD RippingReplies: 40Last Post: 4th Mar 2010, 11:47 -
help with megui error plz
By runLoganrun in forum Blu-ray RippingReplies: 1Last Post: 17th Feb 2010, 22:43 -
Help PLZ! subtitle problem.
By Ajimal in forum Newbie / General discussionsReplies: 2Last Post: 15th Feb 2010, 23:25 -
Help with Mac The Ripper Plz!!!
By ILoveMovies12345 in forum MacReplies: 2Last Post: 24th Apr 2009, 12:08 -
plz help
By sajjad223 in forum Video Streaming DownloadingReplies: 1Last Post: 4th May 2008, 11:12
