I did everything as explained with VirtualDub, started frameserver, opened tmpgenc, and this message pop: "Illegal floating decimal point calculation order" I really don't understand why. I have followed step by step explanation how to convert DivX to VCD with subtitles on. I converted the SRT to SSA. EVERYTHING properly...
Results 1 to 9 of 9
go to http://math.berkeley.edu/~benrg/avisynth-apps.html
and download the file for tmpgenc and follow the
instructions -
Gorgy:
That is a dead link. Anyway, the Newbie Guides say:If TMPGEnc freezes or crashes when converting or you receive errors such as
Unexpected decimal point calculation
Try first to change the codec reader settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 and try open the video.Hello. -
And frameserver is turned on, and it is the only thing you have run since booting your computer, right?
Hello. -
Thanks, ppl. I tried everything. Problem remains. No bad frames found. The message "Illegal floating decimal point calculation order" pops up at the begining of the ecoding with frameserve. I'm blocked. Totally. If you have some idea...save my hours of searching. Thanks
Are you adding subtitles to your movie file?
Common cause: damaged subtitle file. Open the subtitle file using Sub Station if you are using ssa subs (you should get an error message that the subs are wrong version) and save them again. Otherwise, use one of the many excellent utilities, open the subs (say in Subtitle Workshop), export them to another format, and try using the resulting file instead (you can use the Textsub plugin for Virtualdub).
Cheers
Virtualdub frameserver error
By AwesomeRickyC in forum Video ConversionReplies: 6Last Post: 5th Jul 2010, 15:34 -
Can't navigate mpeg-2 output from TmpgEnc (VurtualDub as frameserver)
By Alex.the.pretty.good in forum Video ConversionReplies: 2Last Post: 3rd Mar 2010, 15:28 -
Error message with XviD4PSP - encoding .TS to X264 MKV
By Phat J in forum Video ConversionReplies: 2Last Post: 9th Sep 2008, 23:51 -
Error message in TMPGEnc 3 with Divx Authoring...
By blasedeviant in forum Newbie / General discussionsReplies: 5Last Post: 22nd Apr 2008, 14:29 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 17:28
