hi folks
i use a geforce 4 with tv-in for capturing. i tried to grab from playstation 2, but already in the preview-screen the picture tends to go down, and in reverse the dropped part shows up at the top.
i use virtualdub for capturing, but i think the soft is not the problem, as i get the same mistake with other prgs, too.
my tv-system is PAL. i used to get better results on my old system (p3 500, hauppauge wintv-card); better means: it worked for VCD. the resolution i get now is of course A LOT better, but if its wrong it doesnt help...
i hope u understood the case, thanx for helping!
Results 1 to 1 of 1
When you can't get the LFE to result in what you want...
By takearushfan in forum AudioReplies: 0Last Post: 15th Feb 2012, 22:44 -
Capturing From VHS Via VirtualDub Produce Strange Result
By max20d in forum Capturing and VCRReplies: 0Last Post: 8th Oct 2010, 22:55 -
ffmpegX problem - Preview gives me wrong subs
By no-xplode in forum ffmpegX general discussionReplies: 3Last Post: 31st Aug 2010, 14:55 -
Result movie from Automkv.
By chuckman78 in forum Video ConversionReplies: 2Last Post: 20th Aug 2008, 13:24 -
Choppy Result
By darkdog in forum ffmpegX general discussionReplies: 1Last Post: 22nd Mar 2008, 22:32
