When I download a VCD I use VirtualDub and compress the audio to 44100, then convert everything to VCD with tmpge. The sound still is off a little near the end of the video. What can I do to prevent this besides the steps listed.
Using Virtual Dub, select Options-->Sync(sic) to Audio. and try again.
Hello. -
you're downloading a vcd and then converting to vcd w/tmpg??Originally Posted by bhack
if you've downloaded a vcd, then you need only to burn.
if you need to change the audio to 44100, then if it's already mpeg, just demux w/tmpg, change the audio, and remux
if it's actually an avi file you've downloaded, then that's a different story...what are you askin' me for...
I'm an idiot! -
I would not burn a downloaded VCD unless I knew exactly how it was formatted. I do not need any more coasters right now, so I burn what I know will my specifications.
Hello.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
