My problem:
I have home movies that I am trying to make VCD's of. I want to cut them up so that I don't have blue in between segments, and when the camera is scanning to a new subject. Sounds easy? It hasn't been.
I have used Virtuadub to capture the video, but I lose sound about 2 minutes into the video.
I used MMC to capture the video as MPEG-1 1.15, and used TMPG to edit, with sound going out of sync (not bad, but noticable at the end of 60 minutes)
I used MMC to capture the video as AVI, and used Virtuadub to edit. Sound is gone after the edit except for maybe the first 30 seconds.
I tried using Pinnacle Studio with the AVI file, but it just crashes (Huffy encoding maybe?)
Shouldn't this be easy? I see a lot of posts referring to splitting the audio and video. I know how to do this with TMPG, but why does this help the video editing? Or does it?
If anyone could point me in the right direction, I would appreciate it!
- Kirk
Whew, you are so unlucky, my friend. Nothing seems to be going your way
I have never done DV. But from what I heard, VDub has problems with DV audio. The author, Avery Lee, says it's because nobody gives him specs about DV audio and he didn't add that support. Looks you have use something else to do your capture and choices are numerous: Premiere, Ulead MediaStudio etc. Hope you can be luckier next time.
Audio out of sync after editing in MPEG Streamclip
By Rhymester in forum EditingReplies: 0Last Post: 7th Nov 2011, 05:03 -
[Audio] Capturing, editing, keeping a/v in sync and dynamic resampling
By rmdeboer82 in forum Capturing and VCRReplies: 1Last Post: 20th Mar 2011, 14:16 -
Audio sync while editing in Pinnacle
By p_uriel in forum EditingReplies: 5Last Post: 13th Jan 2011, 14:13 -
Avidemux editing causing audio sync issue
By perdomot in forum EditingReplies: 0Last Post: 14th Sep 2009, 15:29 -
Audio/Video Out of Sync/Lag When Editing Clips
By DrawnIntoIt88 in forum EditingReplies: 2Last Post: 15th Dec 2007, 08:03
