Pleeeeeze help.
I have just bought a Mini DV Camcorder and a Dazzle DV Editor SE firewire card. I've plugged the wire into the card and the camcorder as the instructions said and have installed the software as the instructions said and I've made a tape ready to put on my computer using the supplied ULead videosuite 4.0 basic and I can't for the life of me get it to output any sound.
I can see the video and record the video but when I play it back with whatever I use, there is no sound. Do I need to link a wire to the sound card or something although I thought that DV carries both video and audio.
The audio codec is unknown apparently although I'm sure it just says that because it's not there.
If I can't find out what this problem is(which I'm sure is just me) then it's gonna go in the F*****g bin!
Thanx for any help.
Jimmy
Comp Spec.
PIII 800Mhz. 32MB Nvidia graphics. Soundblaster 16bit sound.
Results 1 to 1 of 1
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 20:58 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 17:24 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 08:02 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12
