  1. I am using smart ripper / DVD2AVI and then Tmpgenc however after I finish converting in DVD2AVI I then load up TMPGenc and go through the wizard however when it gets to the bit about loading the dv video file it's not in the file location, unless I change the format to all files and then it's there but tmpgenc does not like it.
    Can any body tell me what I'm doing wrong, it may be in DVD2AVI??
    Feb 2002
    newfoundland
    hi, to be honest ur having the same problem that i had, im not sure what my problem was.....but for some reason it works for me now, i go to video part of tmpeg and it will show .d2v file ......i might have changed something in dvd2avi but i can't really remember .......all i can say is keep on trying .....p.s. i did post this on this forum, so u might wanna have alook around for it, to see if somebody replied..
