Is there a patch available so I can use DVD player 3.2 to play a DVD from a Firewire drive without having an internal DVD drive? Apple's DVD player just tells me it can't find the DVD drive so it quits preventing me from playing a DVD from other sources (such as a folder on the hard drive or external DVD drive).
You could use vlc to play DVD's. Thats if you have a G4 and running OSX 10.1 or higher Download here http://www.versiontracker.com/moreinfo.fcgi?id=14738&db=mac
Unfortunately I have a G3 600Mhz imac. So VLC doesn't work to well.
But I have found a fix if anyone is interested. This is for DVD player 3.2 under Jaguar.
Download HexEditor from
http://hexedit.sourceforge.net/
" Notes on 3.2 DVDPlayer on Unsupported machines:"
1. gunzip file to your Desktop from (Part 1 & 2 is to install DVD player if you don't already have it installed)
/Volumes/Mac OS X Install Disc 1/System/Installation/Packages/ Essentials.pkg/Contents/Arhive.pax.gz
2. Extract application package in Terminal.app
% cd ~/Desktop/ (~ is your home directory)
% pax -r -s /./Applications*/ -f Archive.pax
3. And Patch it with binary editor such as HexEditor
DVDPlayer.app/Contents/Frameworks/
DVDPlayback/Versions/A/DVDPlayback
offset 0F5210: change "40 82" to "48 00"
offset 0F78F0: change "40 82" to "48 00"
4. Then you can play DVD with Jaguar on your PreG3 PCI PowerMacs with ATI, various G3/G4 cards, and power of [Xpostfacto] XPF2.2! This was found at XLR8 your mac forum!
Hope this helps someone.
TV laptop firewire dvd player
By c-raig in forum Newbie / General discussionsReplies: 2Last Post: 20th Jun 2010, 06:32 -
DVD player to play Divx through Hard Drive
By craigwojo in forum DVD & Blu-ray PlayersReplies: 8Last Post: 20th Jan 2010, 10:16 -
Is there a player that will PLAY dvd folder from a flash drive?
By silver007 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 8th Oct 2009, 16:03 -
Is there any DVD Player with FireWire output? (no recorder)
By Sean_ve99 in forum DVD & Blu-ray PlayersReplies: 24Last Post: 4th Jun 2009, 14:58 -
DVD player with Firewire (1394) out
By PizzaPete in forum Capturing and VCRReplies: 9Last Post: 23rd Oct 2008, 01:05
