  1. Hi
    On all SVCD's i have made - using either TMPGenc or CCE 2.5 - the time shown on my standalone player is approximately 2/3 of the actual time.
    However SVCD made from a downloaded mpeg2 file shows correct time on the standalone player. This has made me suspect the mpeg2 encoders create some information in the header/trailers causing this. Are there any tools available to view/manipulate the header/trailer info?
    Has anyone else had the same experience?
    Regards
  2. Have you tried remuxing your video with bbMPEG?
    Regards.
    Michael Tam
    w: Morsels of Evidence
  3. Hi
    Thx. for your response.
    It is muxed with BBMpeg (DVD2SVCD).
    Regards
  4. Had a similar problem on XVCDs where the bit rate was none compliant. I think it should be 2520Kb/s for SVCD, if that helps.
  5. Hi
    That sounds reasonable. All the SVCD's I have encoded myself is VBR - in order to squeeze more on each cd.
    I'll try to make a CBR 2520 to check it.
    Thx a lot
  6. SVCDs are allowed to use VBR encoding...
    Do you know what you did differently with the downloaded MPEG-2?
    Or, what is different about that MPEG-2?
    Regards.
    Michael Tam
  7. Hi
    No I don't know what specs the downloaded have, I'll try to check it out tonight.
    Thx.
