x
I have a question about VCD recording. I have succesfully coverted a AVI to a VCD to play on a standard DVD/VCD player. The problem is that the VIDEO quality is very poor. I am uising VIrtual Dub V1.49 and added 2:1 reduction (high quality filter) and DIVX 5.0 for video/compression and 1150Kbps. Also full processing mode on Audio and 44100Hz conversion/sample rate. I am using TMPGE for encoding. I opened the AVI inforamtion for fps and it was 11.988 so I selcted the standard NTSC. The last step I used CDRWIN 5.0 to burn to a 80min/800 MB cd. If the FPS are as low as stated above will I never get a good quality VCD. What is the lowest FPS I should use inorder to convert and burn a quality VCD??Thank you for your time in advance and I appreciate any suggestions you have.
1) what is the resolution of your AVI file?
2) why don't u use 4:3?
3) are you sure about the 11.988 fps?
4) does your avi look good?
5) try making an SVCD in stead => better quality
6) Select CONSTANT QUALITY (and make the numer 100, in SETTINGS next to CQ) instead of CONSTANT BITRATE.
...Wanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
) what is the resolution of your AVI file? 352X240
2) why don't u use 4:3? Using TMPGNE or Virtual Dub
3) are you sure about the 11.988 fps? Yes it is as shown in Virtual Dub
4) does your avi look good? It is not perfrect but better than VCD. Does it lose quality when converted and burned??
5) try making an SVCD in stead => better quality Tried not any better
6) Select CONSTANT QUALITY (and make the numer 100, in SETTINGS next to CQ) instead of CONSTANT BITRATE. Where is this setting
Question : Is is true that if FPS is 11.9988 that the quality will not be good?
Garbaage in Garbage out
Your help and ideas are appreciated Thanks!!!!!!!!!!! -
Fashiondon2:Why are you using divx?At bitrate 1150 it's already a highly compressed file and then you compress it again to vcd.So,there is one compression too much.When capturing,use some lossless codec,Huffyuv for example.
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 10:41 -
Good quality? What changes could be made?
By darkdream4 in forum DVD RippingReplies: 78Last Post: 11th Jan 2010, 22:35 -
how good quality is...
By Cazz in forum AudioReplies: 2Last Post: 23rd Jul 2009, 09:23 -
Have I made the quality too Good?
By criddle in forum Video ConversionReplies: 1Last Post: 4th Apr 2009, 04:37 -
What are good specs for a high-quality MP4 file? (Will look good on my 40&q
By HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 04:18
