  1. Hello guys, I'm having trouble getting the subtitles where I want. What I mean is, I feel that the subtitles in my DVD-ripps are to high up!? When I'm converting my DVD's to SVCD using DVD2SVCD and I make the subs permanent and so on. I'm using the default settings which means that Y=
    -1. I've tried some different settings but it doesn't seem to work. Please if anyone out there know what to use - please tell me.
    Second I'm just wondering if anyone can tell me if something is wrong or does it really take 11 - 15 hours per ripp???
    Sorry for the bad english!
    -|-"The Time Flies When You're In A Coma"|-
  2. 1) did you look at the location of the subs in the original DVD? perhaps, the subs were that high up in the original DVD...
    2) try not using the all-in-one proggies......check out these sites to add subs
    this is good if you using smartripper->dvd2avi->tmpgenc->nero:
    http://www.doom9.org/index.html?/subtitle_guide.htm
    this replaces dvd2avi as the frameserver with flaskmpeg:
    http://www.vcdhelp.com/dvdtovcdflask.htm
    having both of these has given me perfect subs...
    in terms of encoding time, it depends on your CPU power, which is critical.....but also your settings, (i.e. 2 pass vbr, motion seach accuracy affects encoding time alot, filters like adaptive de-interlace also adds to encode time)
