I used TMPGenc to Encode my ASF copy of the 7th DBZ movie, and Somehow, It removed mostly all the sound. Can anyone tell me why it does that?
(note: the original does have full sound)
Results 1 to 9 of 9
ASF is a bs gatesoft propritary file type...they dont play well with others...
I have had some luck using virtualdub to convert to avi then using tmpg.....or use virtualdub to sav sound as uncompressed wav file then use that as audio source....... -
As Mad said, try saving the asf to avi using virtualdub 1.3, then turn it to mpg with TMPG
LOL @ BS Gatesoft
Sounds like you may be missing a codec (MP34)...check the tools section for what ya need ....or down load the nemo codec pack lite.
Would it be a faster conversion if I split the aud and Vid, or If I Convert the ASF?
TMPEGenc h.264 conversion error
By iGnight in forum Software PlayingReplies: 2Last Post: 16th Jan 2011, 10:14 -
MKV to IPOD conversion error
By ganjasmoker in forum Video ConversionReplies: 6Last Post: 7th Nov 2009, 23:20 -
Error with FAVC Video Conversion
By IllusionOfLife in forum Newbie / General discussionsReplies: 3Last Post: 8th Sep 2009, 17:38 -
Auto GK conversion error:
By sibaroochi in forum Video ConversionReplies: 1Last Post: 28th Jan 2009, 05:26 -
Divx conversion error with VirtualDubMod
By newnews in forum Video ConversionReplies: 4Last Post: 8th Feb 2008, 15:15
