Hi all,
I'm not sure if this is the right section but I am a newbie so here I go.
I have a DVDrip of a movie but its been given to me on 2 CD's, both files are .avi and what I want to do is join them together and then reduce the file size so the whole film will fit on 1 CD.
Please could you give me some advice on how I can do this and what tools I need.
The info for the first disk is:
Frame rate:23frames/per second
Data Rate: 176kbps
Video Sample Size: 24bit
Video Compression: DIVXMPG4 v3
I haven't finished getting the second disc but I think its the same.
Well thanx in advance for any help recieved.
my advice: spend the extra $ for a second cd. by the time you get this on one cd,the quality of your video will be gone 8)
Cheers mate,
I would use an extra disc but its for a friend and he asked me if I could put it on 1 disc.
I have joined the 2 avi files together and was wondering if there was anyway to reduce the file size from 1.36 GB to 700mb ? -
the only way i know of to do that would be to re-encode the file(you will be able to stipulate the final file size). this will result in poor quality tho.
Run them thru VirtualDub and use DixX(5) encoder. Using a bitrate calc, you can get a bitrate that lets you fit the movie on one CD, once you know the length of the movie. But, as said, beware - Trying to squeeze 1.36 GB worth of movie down to 700 MB will result in really low picture quality.
/Mats
Batch "file creation from a text file, Placed into a created directory
By Muther in forum ProgrammingReplies: 5Last Post: 24th Sep 2015, 19:29 -
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
Can Video File Be Uploaded (file share) And Downloaded in PAL Country
By studioc in forum Video ConversionReplies: 9Last Post: 3rd Nov 2009, 15:34 -
changing ifo file names on same file ext of diff dvd files
By holliquinn in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2008, 06:02 -
Converting VOB file to MP4 file. Video is perfect, audio is nonexistent.
By jdfrosty in forum ffmpegX general discussionReplies: 6Last Post: 17th Jul 2007, 19:31
