Hello Experts,
I have burned successfully several SVCD´s from DVD using DVDx and Nero. (1 DVD -> 4 SVCD´s)
Now I would like to reorganize the files. This mean merge the MPEG2 files in one and split them again (I would like to create more tracks to make the navigation more easy)
While I can read easily the created MPEG2 files with PowerDVD is impossible to open the MPGE2 files stored in the SVCD.
- If I try to move the files to an other SVCD with Nero, it tells me that the format is not correct (allthough it can be displayed without problems with a DVD player and it was burned with NERO!
- with TMPGenc (MPEG tools -> split & merge) is also not possible, the format seems to wrong.
- With the other tools MPEG Encoder is also not possible
I have already loaded the free MPEG2 coded from ELECARD and run the REGISTER.BAT file. However no program can read the files.
So it seems to be impossible to do something with this SVCD MPEG2 files. I can display them with the DVD player, but no more..
Any hint ?
Thanks!
Alex
Results 1 to 1 of 1
Merging 2 mkvs into one
By leoficz in forum Video ConversionReplies: 8Last Post: 19th Apr 2012, 06:31 -
Merging files
By drtbray in forum EditingReplies: 12Last Post: 13th Apr 2012, 16:08 -
MKVToolnix merging help
By SunnyHours in forum MacReplies: 7Last Post: 2nd Dec 2010, 15:39 -
Merging mpeg
By drgt in forum Newbie / General discussionsReplies: 2Last Post: 20th Sep 2010, 05:19 -
Merging M2ts
By a1677c in forum EditingReplies: 1Last Post: 21st Jul 2007, 08:08
