I'm about to purchase a new pc with windows xp, am I likely to run into any problems using TMPG ENC AND VIRTUAL DUB? Any advice would be welcome.![]()
I am running XP on my AMD Athlon 1900+ PC and have had no problems whatsoever with these 2 progs. The faster PC the better though coz it will decrease the time TMPGEnc takes to encode to Mpeg1/2.
Cheers mate,I'm getting an 1800, so how long does it take you to encode say a 2 hour movie, how long for each 1 hour disc so to speak.
It depends on whether you encode to Mpeg1 (VCD) or Mpeg2 (SVCD) and whether you apply filters (if so, how many). When i encode to VCD with default precision search it takes 2 hours for 2 hour movie. To VCD with highest precision search and noise reduction filter it takes 3 hours. To XVCD with VBR 2 Pass it takes 4-6 hours depending on how many filters are used. Haven't encoded to SVCD yet, so can't tell how long would that take.
Cheers
Need advice
By Nator in forum ComputerReplies: 2Last Post: 29th Mar 2012, 11:06 -
New PC advice
By garryward in forum Video ConversionReplies: 1Last Post: 29th Nov 2010, 13:27 -
Advice on a new audio/video system(I need advice and direction)
By hellfire45 in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2008, 00:20 -
Looking For Advice. I'm hoping to get some advice about a DVD burner
By wtsinnc in forum DVD & Blu-ray WritersReplies: 5Last Post: 4th Dec 2007, 23:39 -
I need some advice
By CM World in forum MediaReplies: 1Last Post: 6th Aug 2007, 05:58
