Hi ppl,
I am new to this and am looking for the best way to
do things.
I am trying to convert all my existing tape collection
(PAL format)
into digital format and i am looking for BEST result.
If the above is my aim. I should capture in high-res
and when converting to MPG using TMPEnc, I should set
source as Interlaced and use a DeInterlace filter yes?
Also, can i safely assume making a VCD should NOT be my
aim if i am looking for best result? What should I be
aiming to produce at the end of the day?
I know I should have done some research b4 i post but
I just wasted a week burning 8 VCDs which has CONSTANT
annoying JERKS all over the place... and i really need to
find and solve the problem b4 i go crazy.
Thank you for your time.
Klick the newbie... obviously.
I asked this question some time ago - the consensus was that you capture in the highest resolution you can in the lowest compression.
Yep, try and keep compression for re-encoding below 10:1 preferable in lossless 2.5:1 huffyuv, but we don't all have the space for that.
I would say for a beginer you should capture at your output resolution VCD = 352x240. If you are more advanced or are going for SVCD capture at full frame 480 scanlines, but be aware that full frame has drawbacks as interlacing really can make a mess of your video. -
Thanks for the tip.
btw, I keep hearing peeps talking about VirtualDub.
It seems really popular but I can't get it to work
in mine. I've a AIW Radeon and have followed instructions
and I can see my card in VDub but the video shown is
REALLY REALLY bad... maybe it didn't know the source was
PAL and not NTSC... where do I set this in VDub?
If I use ATI's capture sw ... it is fine.
Klick.
VDub is good, but for just capturing I like AVI_IO better. I get less dropped frames with AVI_IO, but that could just be my setup. But then I'm new to capturing so what do I know
2nd best option to capture video to computer from Camcorder??
By Canes in forum Capturing and VCRReplies: 15Last Post: 10th Jun 2010, 07:17 -
Automatic - Programmed Capture into DV of analog source via Firewire Device
By lasith in forum Capturing and VCRReplies: 5Last Post: 12th Feb 2010, 05:03 -
DVMixerPro 'soft toaster' live analog source motion artifacts
By cybertheque in forum Capturing and VCRReplies: 0Last Post: 10th Aug 2009, 06:04 -
Analog capture poll
By goggy59 in forum Capturing and VCRReplies: 3Last Post: 4th Jan 2009, 20:28 -
Capture problems, PAL60 option
By CoronaStar in forum Capturing and VCRReplies: 1Last Post: 11th Oct 2008, 08:38
