    Jul 2001
    Maryland
    Should windows see the actual drive or the drive kit?
    I installed my Sony DRU500A through a 1394 Kit and windows see's the kit and a SPB2 IEEE 1394 compliant device.
    I expected Windows to see the device and put it under the CD/DVD tab.
    Windows reports instead a "Pyro 1394 IEEE 1394 Box + Repeater"
    However, all applications see a DRU500A
    Jul 2002
    BATON ROUGE, LA - U.S.A.
    this is correct.
    Where I walk, I walk alone. Where I fight, I fight alone.
  3. Swollen Member
    Mar 2002
    Kanuckistan
    Windows will not see the drive directly, but stuff like Nero will. However, be aware that some software may not recognize the drive. This is true also of some firmware updaters.
    Jul 2001
    Maryland
    as long as Nero can see the drive, i'm happy.
    Cause i can burn images through nero
  5. Make sure your External Box has the OXFORD 911 Chipset.. because the older chipsets don't work with this drive. and the OS does not see it.
    Jul 2001
    Maryland
    How do I set DMA for this drive?
  7. Member The village idiot's Avatar
    Apr 2002
    Adrift among the STUPID
    You don't, or rather can't. Shouldn't be a problem, never has been with my drives.
    Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
