I have read lots here but cant get started!
I have lots of video clips captured from television with a Miro DC 30+ card and saved on my hard drive.
When I try to open them in TMPGenc I get "cannot open- file unsupported"
When I look at the Properties/Details of these .AVI files I see
Video Format: 384 x 288 , 25FPS, 585kb/sec, UNKNOWN FORMAT!
I have read lots on this site but cannot see any reference to this problem ( yet it is probly really common)
I have downloaded: VirtualDub and Nimo Lite .
I have these codecs: in Multimedia /devices/Video/
Indeo V 3.3
Indeo V5.06
Indeo V4.4
Indeo RAW YVU9
MS Video 1
MS YUVY
MS YUV2
MS YUVU
VDO net VDO wave
I see that on System.ini there are things like:
MS ACM DIVxA 32 Plus others
Whats happening here , what am I doing wrong
These movie clips play perfectly om MS Media Player 6.4
ronbruce
-> MJPEG
Install Pic Video MJPEG codec or Morgan MJPEG codec (both are shareware). There might be a free version floating around and maybe on the Nimo pack (check it to make sure). -
MIRO's use MJPEG for compression. MIRO's come with a hardware MJPEG codec chip. TMPGenc requires a software MJPEG codec to encode the .avi files into .mpg.
MJPEG is the type of compression used. -
Thanks guys,
tracked down some russians that had Pic Video mjpeg thru google, downloaded ( with some trepidation)
tried a file in tmpgen , hey it opened,
thanks again
ronbruce
Unsupported audio format in MKV file on LG 47LW5600 TV.
By kmplsv in forum Video ConversionReplies: 5Last Post: 23rd Feb 2012, 09:03 -
Unsupported format or damaged file -> ?
By ermetekos in forum EditingReplies: 1Last Post: 31st Mar 2010, 11:56 -
Captured S-VHS format
By Rinsin in forum Capturing and VCRReplies: 24Last Post: 28th May 2009, 12:05 -
Unsupported FLV codec or format
By lovyagin in forum EditingReplies: 25Last Post: 11th Dec 2008, 23:13 -
Premiere 6.5 - unsupported compression format.
By vodmare in forum EditingReplies: 3Last Post: 28th Jan 2008, 16:51
