I have a pinnacle pro-one capture card that came bundled with adobe premiere and
Pinnacle Impression dvd pro. I can capture fine, however, I cannot export anything
into the pinnacle MP2. I obviously need to compress the files from avi format, but every
time I try I get an error message saying "Error writing file (disk full?)" I have an 80 gig
with nothing on it that I'm trying to write to, with a clip only 3 minutes long....
I have tried to adjust every setting, but to no avail. I'd really hate to think I spent $900.00
on a system that isn't going to work for me, can you give me any advice?
Thanks,
Remember when the only way to see a movie uncut was to go to the theatre?
The workaround is that you have to go into the settings button and load the correct MPEG-2 export mode. Every time. You cannot just use what you selected last time you exported. Even if the same mode is already selected, you have to reselect the same thing again. Hopefully Adobe or Pinnacle engineers will read this and fix the problem eventually.
Premiere Pro 'Error Compiling Movie - Unknown error'
By koberulz in forum Newbie / General discussionsReplies: 12Last Post: 16th Sep 2012, 17:43 -
error+restart while loading Premiere Pro
By pixiecate in forum Software PlayingReplies: 1Last Post: 22nd Oct 2009, 15:19 -
Adobe Premiere CS3 error
By tjcook1 in forum EditingReplies: 0Last Post: 23rd Sep 2009, 23:32 -
Adobe Premiere Pro CS3 ERROR =/
By ervand in forum EditingReplies: 8Last Post: 11th Nov 2008, 23:28 -
xVid in Premiere CS3 Error
By goodjj22 in forum Video ConversionReplies: 2Last Post: 20th Mar 2008, 15:49
