I have a LG 32x10x40x CD-Writer and it comes with EasyCD Creator 5 Basic. I have been using it for data backup and home movies backup. I'd like to create VCD/SVCD for some home moves and send it to may family out of the country.
Can someone please tell me should I simply upgrade EasyCD Creator 5 to the latest version which comes with "Create VCD" ? Or I should buy other VCD/SVCD burner software. If so, what product would you recommend ?
PS: I'm running Win XP on my Pentium 4 1.8GHz PC with 512MB RAM
Thanks in advance any of your advise.
Regards
If you are looking to create S/VCDs, my advice to you is to not buy anything!!
Arguable, the best (in terms of power and flexibility) S/VCD authoring system is VCDImager and it is open source (i.e., free software). VCDEasy, one of the GUIs of VCDImager allows easier usage for beginners and can make some simple VCDs (with menus and chapters!). Included with VCDEasy is CDRDAO (an open source burning proggy) that allows you to burn the VCD/SVCD images made by VCDEasy.
There are a lot of resources on using VCDImager and VCDEasy on this site so don't hesitate to use the search function and find out more.
VCDImager: http://www.vcdimager.org
VCDImager Authoring Guides: http://www.vcdimager.org/guides
VCDEasy: http://www.vcdeasy.org
Regards.Michael Tam
w: Morsels of Evidence
Yet Another What Burner Should I Buy . . . but for MAC-External
By Doctor X in forum DVD & Blu-ray WritersReplies: 11Last Post: 17th Apr 2010, 04:08 -
What burner should I buy ?
By aneng in forum DVD & Blu-ray WritersReplies: 37Last Post: 3rd Mar 2010, 23:06 -
Looking to buy a new DVD Burner...Need advise
By BrokenOne in forum DVD & Blu-ray WritersReplies: 3Last Post: 27th Mar 2008, 09:43 -
Which burner to buy
By cd090580 in forum DVD & Blu-ray WritersReplies: 12Last Post: 28th Feb 2008, 21:05 -
Which External Dvd Burner To buy???
By ofield in forum DVD & Blu-ray WritersReplies: 9Last Post: 22nd Dec 2007, 01:10
