Looking for programme to remove loud pops and sound spikes from mpgs.
On some mpgs I have there apparently is some bad data which causes there to be a picture glitch and a loud scratch or popping noise whenever the bad section is played. I use SmartPar and WinRAR to assemble many mpgs from Rar files I acquire and 99% of the sound/picture is fine. I have TMPG which has been helpful somewhat but very time consuming to edit out each pop.
I am hoping there is a programme I can use to process my mpgs which will automatically MUTE any sound above a particular default I set up. If the normal sound is between 3-5 on the VU metre and the pops are at 10+, I can set it to mute anything above say a 6. I hope this is making sense to someone out there and others have found a solution. Thank you for helping.
Phil
(`58 Toyopet RS20, `63 Toyopet RS32, `68 Crown MS55,
`69 Corona RT52, `69 Corona RT43, `72 IHC Loadstar 1700)
Reply to Philvener@earthlink.net
Fax: (603) 506-0352
ICQ: 122078893
Results 1 to 10 of 10
cool edit pro. www.syntrillium.com
Swim with me
And we'll escape
All the trouble
Of the present age
Finally free -
If there is a picture glitch as well,why not just extract the video and audio (if you know the frames numbers of bad frames)with Virtualdub and save as new stream.
"Today is only yesterdays tomorrow" -
I could do that but it would be very time consuming.
I would have to edit them one at a time.
Thank you though.Phil (`95 4Runner,`68 Crown MS55,`69 Corona RT52,)
Reply to Philvener@earthlink.net -
Originally Posted by geek rock
Thanks for the tip! Sounds as if it'll do the job alright. I wonder if there are any others perhaps a bit less $$ or with less bells & whistles.
Wow! Now here's a neat lil proggie.Originally Posted by wee haggis
Nice graphics and reasonable price.
I will try the demo and see if it can remedy my worries.
Has anyone any personal experience with this Goldweave you care to share?
I appreciate all the helpful replies I am reading so soon after my initial post.
Thank you all for your ongoing support.Phil (`95 4Runner,`68 Crown MS55,`69 Corona RT52,)
Originally Posted by 58Toyopet
Well, I tried the Goldweave and it is rocket science to figure out. I tried just about all the options and tabs it had and still could not get it to work.
I've used Goldwave for audio recording and editing. (Haven't tried it with audio extracted from video, but as long as you don't change the file length it shouldn't be a problem.)Wow! Now here's a neat lil proggie.
It DOES require a little experimentation. It has a lot of options, and they aren't automatic. For instance, the pop/click filter can make the sound muddy if overused. Don't expect a sow's ear to become anything better than an attractive sow's ear purse.
It also takes up considerable disk space. To enable the "undo" feature you are keeping essentially two copies of the sound file: your modified version and the "undo" version. And it's only one level of undo, so you have to take things step by step. You must "initialize" a section of disk space every time you load a file. Like video editing, it helps if your hard drive is defragmented before you start.
One thing that threw me (and which may have thrown the guy who couldn't get it to work) is that Goldwave has its own recording level knobs! You get them by clicking the "control panel" box and clicking on the check box. You can only check one audio source at a time, but the "line out" one apparently takes whatever is set on your sound card's Windows mixer. These are only used if you're taking analog sound in and recording your own WAV files. (It converts to a lot of audio formats, although you may have to find a freeware MP3 audio codec like the Blade, or buy one like the Fruenhoffer.)
Hope this helps. (The program is really worth paying for. I use it to convert audio tapes and radio broadcasts to MP3's.)Animation and geeky reviews and podcasts at
Cartoon Geeks (http://www.cartoongeeks.com)
Remove sound that is at a louder level?
By gutterboy in forum AudioReplies: 11Last Post: 27th Jun 2011, 11:22 -
Is there any way to remove sound echo from a video?
By johnharlin in forum Newbie / General discussionsReplies: 3Last Post: 1st Jun 2011, 12:11 -
I need to remove sound from footage.
By Lensmeister in forum Newbie / General discussionsReplies: 10Last Post: 7th May 2009, 02:28 -
DVD movies Sound effects way loud voices... not so much.
By maxx409 in forum Newbie / General discussionsReplies: 7Last Post: 15th Feb 2008, 13:57 -
How to remove sound tracks from a DVD?
By htp367 in forum EditingReplies: 5Last Post: 11th Oct 2007, 22:51
