  1. Am i going to see any differnce in quality if i record my vhs tapes to my digital camcorder (with tbc) then use my digital camcorder to capture and make SVCD/DVD-R??
    Just curious if i will see a dramatic difference or what?
  2. Member vhelp's Avatar
    Mar 2001
    New York
    downer,
    most likely not, but I have found (IMO) that the transfer from VHS to DV
    cam (on mine anyways) is sometimes a little better. Not the quality, but
    the jumpyness - it's sometimes lesser than if I had captured it direclty w/
    my capture card.
    However, I also have a DC10+ card, and this card does (IMO) a little bit
    better than a regular capture card ie, ATW, WTVGO etc.
    Also, the content also makes a difference as well in the capture (or transfer,
    if using DV)
    I have found, some TV recording I did, came out better at time, and worse
    at time when comparing store bought videos.
    So, bare that in mind to, when you see it looks good on some but not on
    others.
    Other issues to consider, but I'll stop at this point.
    Just go and give it a try, unless you don't have access to it just yet.
    Why don't you just try it and see for yourself.
    good luck.
    -vhelp
