Oh yeah - I also have the latest xvid codec installed, so I don't think that's an issue.
Results 61 to 90 of 102
Thanks so much. I had a file TMPGEnc was having a lot of trouble with but your instructions made everything run smooth.
XviD-fov? Is that just a file name (i.e. somebody renamed the file) or a format? Check the properties of your AVI to determine which codec was used. Are you encoding to Mpeg1 or 2? Freezing in TMPGEnc and VD not accepting them might point to bad files or incorrect file extensions. Bad files - fix them (DivFix) or download new ones, incorrect extensions - use Gspot to determine the correct format and change the extension.Originally Posted by gwonel
If still having problems, send me a fragment of it and i will check what's wrong with it (email address is in my profile, send file no bigger than 1.5MB).
Regards. -
Thanks O kewl. Worked like a charm.
Still needed to extract the wav file for sound.
Only question is, you mentioned turning back the settings in VFAPI.
What are the default settings?
Dumb me forgot to write them down.
Should I be keeping 2 instances of CurrentCfg.tpr or TMPGENC.ini for eg.?
Thanks for all the help here...
Right-click on the selected plug-in in VFAPI plug-in window and choose Reset to recommended setting.
Regards. -
O KEWL
Cheer's for your advise i got a better copy but went 1 step further i formatted my hard-drive re-installed everyting and hey presto jobs a gooden.
Cheers once again
Can someone help me after using this method after TMPGENC starts to encode the movie it freezez at 11 minutes
Alright I ran Divfix and it borught up the errors that are in my xvid what do I do now?
Hi there!
I've converted several DivX videos into SVCD and never had any problems. But this Xvid codec turns me completely mad. I've changed the plug-in settings in TMPGEnc, but my computer still crashes at random frames. I've tried frameserving from Virtual Dub, but nevertheless I'm expecting the same problems. Does anybody have a reason?
BTW: I'm still trying to get the best results in quality when converting into SVCD. Please tell me about your settings in TMPGEnc, especially which rate control mode do you prefer (2-pass VBR, CQ etc.). How do you calculate the bitrates to get near the 800MB file-size (80min CD-R)? The bitrate-calculator doesn't give useful results.
Thanks for your suggestions. Greetz,
Hector -
It sounds like your XviD AVI file has got some bad frames. Use DivFix or Virtual Dub to fix them.
I prefer 2-pass VBR when encoding to SVCD. As for the other settings - i would advise you to experiment with them to suit your own taste since the quality that is acceptable to me might not be acceptable to you and vice versa.
Bitrate? I usually encode 2 small (1 minute long) fragments of the movie first (using the same bitrate settings for both); one with little or no action at all and the other one with a lot of movement. Divide the total size of the two files by 2 and multiply by the length of the movie in minutes. Then i adjust my bitrate settings (usually the average bitrate) depending on the result. Works quite good for me
but you can find some quite precise bitrate calculators in the Tools section on your left.
Regards. -
Well, I've checked my Xvid twice, first with DivXFix and then with Virtual Dub. Both of them didn't respond any errors. I don't think that the AVI-file is corrupted, because my system crashes at totally random frames.
Now I'm experiencing new problems: sometimes the encoded MPEG2-stream's stuttering in motion sequences, even the playback in my DVD-Player. I'm getting very frustrated.
BTW: I'm using the latest version of TMPGEnc and the Xvid codec. -
Hi,
I have not tryed to encode my xViD .avi movie of "bloodworks" yet. I do not have the cyberlink MPEG-2 decoder plug-in but i do have everything else.....having that will let me convert my xvid compressed avi to mpeg-2 compression?? I want to convert my movie to mpeg-2 which is better then mpeg-1....or is it not worth it?? is it not that much better?? i don't care about how long it takes or how much work i have to do....i just want the best quality possible. is mpeg1 vcd quality?? and mpeg2 svcd quality?? please help...thanx for your time....also, should i convert to mpeg-2 with audio too or should i do the audio with another program like virtualdub??
-dave -
First thanks for the info on how to convert these files. Delete a few before I knew what the deal was
My question is.... is there anything beside this that we have to do differently. I cut my files in vdub. There doesn't seem to be a problem when I cut the file but I really am getting sick of the time I waste on lack on information. So before I begin the encoding process. I would like to be sure that there is nothing else I need to do. Thanks much
HAPPY NEW YEAR!!! -
Sorry guys. I found my answer in this forum. Sorry to waste space. Thanks again for all your help.
Does your system crash only when encoding XviD AVI files? Could it be CPU overheating related problem? What Mpeg 2 plug-in is your TMPGEnc using?Originally Posted by Hexhector
Is this happening only to XviD->Mpeg 2 files? This could be related to incorrect framerate, high bitrate or unsupported Mpeg 2 plug-in. Check that your XviD framerate corresponds to your Mpeg 2 framerate (if not - use the framerate conversion guide (link to it can be found in my guide) before loading your AVI into TMPGEnc), check your player's maximum acceptable bitrate (see DVD Players section on your left) and check which Mpeg 2 plug-in is used by your TMPGEnc.Originally Posted by Hexhector
I would advise you to use 2.58 version of TMPGEnc as the latest version is known to have some bugs (like same file size whether selecting non-standard or standard Mpeg 1 encoding option when using the "The newbies guide to fitting a movie on one CD using TMPGEnc" guide). This may well be the root of your problems.Originally Posted by Hexhector
You have to have some kind of Mpeg 2 plug-in to encode to SVCD. If you have successfully encoded to Mpeg 2 before, set the used plug-in's priority to 0.Originally Posted by NYTino20
Normally Mpeg 2 is of better quality than Mpeg 1 but it depends on bitrate and settings you choose when encoding your file. You have to decide for yourself whether it is worth it or not as the quality acceptable to me might not be acceptable to you. Most of the time you will have to choose whether to go for the best quality or the least amount of space (CDR/RWs) your file will occupy or some kind of compromise.Originally Posted by NYTino20
Yes and yes.Originally Posted by NYTino20
I usually extract audio using Virtual Dub for loading into TMPGEnc separately to avoid possible audio sync issues. However, some people prefer not to do so for exactly the same reason. So again, it is your choice...Originally Posted by NYTino20
Regards. -
Hi 0 kewl!
Probably you're right. A few weeks ago I have had some system instability problems. My memory module wrecked and my Athlon XP 1700+ looked like it overheated. For this reason I've mounted a modified heatsink and several fans in the case to improve the air-flow. Now the CPU is running at a temperature of 107°F. I've installed TMPGEnc v2.58 as you mentioned and started MP2-encoding. The encoding-process finished without any problems for this time. I'll try to convert two or three different Xvid AVI files and I'll post the results afterwards.
Greetz,
Hector -
the method works almost perfectly! thanks!
Just one stupid question... when i changed the VFAPI plug-in priority settings within the environmental settings, i forgot to write down how they should be in order to convert a normal DivX... but now i want to convert a normal DivX... anybody can help me? thanks! -
Hi.
Question.. I set the settings per your instruction. Loaded the movie (die another day). Started and got a green gobbled screen with the movie playing in the background. I encoded for about 2 min. and watch what I had....I had just what I saw. What am I supposed to be seeing. What is wrong?
There is also a warning about the film being coded to prevent encoding. I assumed that adjusting the plug-in would take care of that. Any suggestions would be really appreciated.
Sorry for the late reply, i'd assume you've sorted this out by now.... If not:Originally Posted by nikopiz
DirectShow Multimedia File Reader -1
AVI VFW compatibility Reader -2
The rest of them all set on 0
(Although you might want to keep your DirectShow plug-in on high priority to enable TMPGEnc to handle AVI files better)
Have you installed the latest XviD codec?Originally Posted by rickki804
When does the warning come up? What exactly does it say? Is it one of those warnings that appear as a text when watching the movie itself (like subtitles)?Originally Posted by rickki804
Regards. -
Hi
Great Guide!! Makes perfect mpeg2 movie with those settings in TMPG!!
BUT I canīt not burn them as SVCD in nero or WinOnCD!! With nero there is no sound on it and WinOnCD crashes while "building disk" Both programs said that it isenīt a proper SVCD file!??!? Know anything about that?
Yours Chefen31 -
WooHoo!
Thanks for the guide. I suddenly got a "pointer error" when doing a VBR encode of an Xvid file. Your settings got it working perfectly.
hi O kewl ur guide worked great....i am done converting my movie to svcd however when i try to split the movie using TMPGEnc under mpeg tools an error comes up "Could not open this file with drirect show" can u please help.....i have split and joined my vcd's but for somereason the SVCD one is not workin...also my TMPGEnc version is 2.588.44.152 (just to be exact)...plz help
THANKS in advance...greatly appreciated
0 kewl you are the king
. Thank you very much for the XviD conversion tips using TMPGENC worked a treat and got rid of my 3 day long running headache of converting a XviD file. I wanted to thank you the day it worked but had to wait 3 days as i was a new member.
Regards
Jay -
Hello all,
First of all, please accept my sincere apologies for replying so late (special apologies to you, Chefen31, since you had to wait 2 weeks for my reply) and i hope that your problems have been sorted out by now. If not, see my replies below. For those interested, i was on holiday, hence the late reply.........(some of us DO have a life apart from VCDHelp.com
and that is not to say that VCDHelp.com isn't worthy to be somebody's only life).
What template are you using to create these files? It might be that you are by mistake making a XSVCD by adjusting a bitrate or resolution. No sound with Nero? Is there a sound in Mpeg 2 file? Don't know about WinOnCD, but crashes could be explained by buffer underrun, bad multiplexing by TMPGEnc, bad media (CDR/RW) or low memory available (or HDD space). It looks like the problem in this case might be the audio of your original XviD. What was the audio format and did you do any additional work with it? Was it with no bad fragments?Originally Posted by Chefen31
1. Try to increase DirectShow Multimedia File Reader filter's priority under VFAPI plug-ins when splitting this file.Originally Posted by romy_1986
2. Try this prog to split your file.
3. Try TMPGEnc 2.56 (just to be on the safe side).
Originally Posted by BillyBI am glad to know it is helping others and thank you very much for your feedback, it is greatly appreciated.Originally Posted by DesiLondonBoy
Regards. -
thanks o kewl for the prog...i have one more question howver....how can i open files mpeg 2 files in vdub....cause wen i played the movie (downloaded elecard codec for mpeg2) it was out of sync. this time wat i did was i extracted just the wav audio from the movie and the avi video seperately...then i encoded them in tmpgnc 2.59 and wen i played the movie the audio was out of sync by like 3 secs so i tried to open the mpeg 2 file in vdub and an error came up and said
MPEG Import Filter: pack syncoronization error
how can i fix the movie is there a better guide for convertin xvid to svcd..please help in any way thanks alot once again
I've been trying to convert Xvids of "The Two Towers" for a month. The settings work fine but after encoding 7 mins of video TMPGEnc disapears. Does anyone know what's wrong? Thanks.
hi there i found the second part of this guide help full !!
https://www.videohelp.com/forum/userguides/144959.php
just change the "FourCC Description Code" and it uses the divx codec insteadInovate Don't imatate
AVI (xvid) into TMPGenc plus HELP
By efiste2 in forum Video ConversionReplies: 3Last Post: 4th Dec 2010, 18:30 -
Converting Xvid to MPEG1(VCD)
By Ensign in forum Video ConversionReplies: 3Last Post: 18th Dec 2008, 16:00 -
best avi (divx/xvid) to cd-r (vcd) converter
By waefwaeefwaefw in forum Newbie / General discussionsReplies: 8Last Post: 15th Sep 2008, 13:36 -
How to convert VCD to Xvid (avi)
By nalika in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2008, 17:51 -
Automated XVID to MPEG1?
By SevenNine in forum Video ConversionReplies: 3Last Post: 26th May 2007, 16:52
