I'm running Windows XP Pro, Pentium 3 450 mhz, Pioneer 106s slot loading dvd rom drive. When I open smartripper and click on the opening dialog box, normally(on my other pc) it reads all the files and I begin ripping and it all works fine. On the Pioneer drive, I get an error that says some files are still locked, try unlocking again. I have already tried the drive in the other pc that works with a delta dvd drive, the pioneer did not work there either. I already set the region in windows to 1. I have the same "settings" within smartripper on both machines. The same ones on the walkthrough here at vcdhelp.com. Is it just an incompatibility with the drive? Suggestions? Thanks in advance.
Run the movie in Powerdvd for a few moments, before using Smartripper, then you will not have this problem.
Remove WGA 1.2 doesnt work
By jyeh74 in forum Newbie / General discussionsReplies: 5Last Post: 6th Mar 2009, 23:46 -
get smart doesnt work with DVD Fab
By shoesss in forum DVD RippingReplies: 6Last Post: 7th Nov 2008, 11:52 -
Samsung DVD-HR737 doesnt work with 1-16X DVDs
By bengt39 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 16th Dec 2007, 11:27 -
Some audio doesnt work
By TheEmperor in forum AudioReplies: 2Last Post: 16th Aug 2007, 09:05 -
HELP! DVD Burning VOB files doesnt work
By liam0114 in forum Newbie / General discussionsReplies: 3Last Post: 5th Aug 2007, 17:35
