i've been trying to copy some mpegs from an SVCD authored in Nero to my hard drive by just dragging them onto the desktop, and i get this error:
"The operation cannot be completed because some data cannot be read or written (Error code -36)"
there's nothing wrong with the svcd.. it plays in my dvd player just fine. why can't i copy files off of it? does anyone know?![]()
I don't have a machine with it handy so I'm not sure that it works in OS X, but if you're on OS X you could try vcdxrip (part of vcdimager 0.7). If it works you should end up with a bin/cue pair, an MPG file, and a vcdimager XML file describing the disc. In theory running that XML file through vcdxbuild could recreate the disc, so if this is related to figuring out what Nero does differently that might be useful.
thanks sterno, that's exactly what i'm looking to do!
i'm a bit confused though... i have vcdxrip as a part of vcdtoolsx, but it will only extract mpegs out of .bin files.. not extract files off of a vcd/svcd. i can't find vcdimager 0.7 for os x available to download anywhere... -
http://www.dawnload.net/video_software/video_tools/vcdimager_for_mac.cfmOriginally Posted by behoovedgirl
there you goWhere I walk, I walk alone. Where I fight, I fight alone. -
There are only 2 ways:
Use VCD Copy X http://www.cs.ucla.edu/~nathanst/software/vcdcopyx/index.html
or
Boot up in OS 9 -
ok well i booted into os 9 and tried to drag the files onto my hd, and it says there's some sort of disc error, so that didn't work.
i decided to try VCD Copy X first since it's GUI, and it worked, but it just gave me a folder with a bunch of .dat files in them. what exactly can i do with those to get them back into mpeg format?
i'm going to attempt to use vcdimager now, because it sounds like it will do exactly what i want... i just don't know if i trust my self with a CLI. we'll see...
Is it possible to install two copies of ffdshow?
By Foxhack in forum Capturing and VCRReplies: 2Last Post: 9th Jan 2011, 13:26 -
Help w/ Digital Copies w/out using iTunes
By tsakdee in forum Video ConversionReplies: 11Last Post: 10th Nov 2009, 22:38 -
bad copies
By freewave in forum Newbie / General discussionsReplies: 7Last Post: 20th Jan 2009, 02:43 -
Copies Of DVD5's
By kpoman in forum DVD RippingReplies: 5Last Post: 23rd Oct 2008, 00:33 -
DVD copies
By JimboS in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 23:33
it worked. thanks ross!
